27mm on the nut and 24 on the bolt.
front is just a 24 iirc? and a screwy through the hole!
just a tip - on the front, the spacers are slightly different sizes. be sure to put the spacers back where they came from or you will bend your discs and the wheel alignment will be out...
(don't ask!)
