got no adjusters on these
sirch345 wrote:Nora2004 has given these ago, see link http://cgi.ebay.co.uk/HONDA-VTR1000F-FI ... 0297271666
Read about and see photo's of his here (starting at the 6th post down) http://www.vtr1000.org/phpBB3/viewtopic ... 7&start=30
The only downside I've come across so far is that these cheaper levers appear not have any bushes at the pivot point. That will mean a shorter life, as alloy is relatively soft. I'm not sure if Nora's has or not.
You're very welcome Georgegeodude wrote: Many thanks Chris
I agree Tony about a phosphor bronze bush, but only if you've the access to a lathe, otherwise it's going to be defeating the object of cheap levers if you're going to have to pay someone engineering firm to do that for you.tony.mon wrote:Easy enough to bore and insert a nice little needle roller, I would have thought. Even a bronze bush would do.
