Fork Springs
oldbikeman
Fork Springs
Post by oldbikeman »
Can anyone tell me if and which fork springs work with standard 98 forks.The originals are too weak.
THANKS
Giddsy
Re: Fork Springs
Post by Giddsy »
I replaced mine with hyperpro progressive springs for about 100 quid and it makes a huge difference...
Re: Fork Springs
If you try a quick search you will find loads of threads on fork upgrades, as the front end is the 1st limitation on the handling side, there are various options:
1) new springs and thicker oil and do it your self [carefull of the debate on progressive vs linear springs]
2) rebuild & revalve [modify the damper stack and the adjuster needle], new springs [linear] by Roger Dichfield a VTR tuning and racing expert Revolution Racing 07970915259 cost about £200 inc postage.
3) fit the front end off another bike........but you still need to revalve & respring.
I did option 2, and am very pleased with the improvement. Others will chime in with what they have fitted.
bazza696
Re: Fork Springs
Post by bazza696 »
I fitted WP progressives, bout 60 quid
