How do adjust the rear brake lever height?
- cunningstunt
I need to adjust the height of the rear brake lever from the previous owners setting but can't figure out how to do it, anyone give me some advice please?
would make more use of a set of butt sliders these days
- benny hedges
Re: How do adjust the rear brake lever height?
on mine i undo the locknut on the banjo bolt on the rear master cylinder, undo the bolt that goes through it into the pedal.
wind the banjo bolt in / out to adjust the pedal height (and amount of stamp you can get on the brake.
then bolt it back up & secure the locknut.
with the standard setup you just turn the locknut under the master cylinder (arrowed)
looks like a 12mm nut
dont forget to readjust the brake light switch.
- cunningstunt
Cheers for that, just done it. Piece of cake when you know how, many thanks mate
