One other point my Storm has 6 gears and i thought that they only had 5. I counted the changes at least 5 times just to make sure, again is this standard
I thought that but i checked it with my Sat Nav and the speed is spot on.. wwll a couple of miles over but that normalvtwin wrote:Hi,
No they are all six speed.
I have a 2001 model with a 19ltr tank and I ride pretty steady and I can't get more than 100 miles before hitting reserve.
Are you sure the bike hasnt had a gearing change which would make the odometer out ?
If i ride around town then i get 90ish before the light comes on, since i've discovered the 6th gear it's made a massive difference to my tank rangeBuckers wrote:It must be counting kilometres. 170/1.5 is about 120 which is still high, but more normal.
I get 90 before light every time, but I commute in town every day and ride like an butt. On long journeys I get 120 before light
