NAME OF TOOL??
seb421
NAME OF TOOL??
Post by seb421 »
what's the name of that special security type tool, like a hex but more like a star with a dot in the middle.... looks like it needs a special type of alen key.
with out it i cant get the lock unit of the storms top clamp :( and dont want to use the impact driver to shock them out.
cheers guy's
Re: NAME OF TOOL??
These any good, the security bits at the back :?: Not sure what size you'll need, but this must be what you mean I guess.
http://cgi.ebay.co.uk/33-pcs-Security-T ... _Equipment
seb421
Re: NAME OF TOOL??
Post by seb421 »
yeh thanks mate,
what are they called do you know at all those on the back row to the right are what i need, i need small ones... god knows what size
Re: NAME OF TOOL??
I would have said the ones at the back are the 9 Security Torx Tamperproof Bits T8, T10, T15, T20, T25, T27, T30, T35, T40
Re: NAME OF TOOL??
Now you mention it Tim, I think my Storm has shear bolts holding the ignition switch in it too.
Re: NAME OF TOOL??
Timbo wrote:Do you mean the ignition switch? That is usually held in with them bolts that snap the heads off as you torque them up, you have to drill them out or cut a slot in them.
correct that is. i got a shiny new top yoke for mine but couldnt get the shear bolts out without drilling them and was off to bulldog so left them.
those security torx... waste of time trying to drill a torx bit (ive tried lol)
i used a broken drill bit to chisel the pin out the middle of the bolt and then used a ordinary torx key.
cliveyandrews
NAME OF TOOL??
Post by cliveyandrews »
I do have a set 3/8" drive, and some smaller screwdriver (hex fit) ones - if anyone ever gets stuck....
Audi, Vide, Tace
