b8stard Security!
seb421
b8stard Security!
Post by seb421 »
just has to buy some torx hex star type tool's to remove a part of the lock (bottom ignition bit) now to remove the steering lock i will have to use a bloody drill as there are no heads on the bolts! and cant find my impact driver
just sold this old top yoke, dont want to wombles it up. dam
seb421
Re: b8stard Security!
Post by seb421 »
Finally sorted it, took me about 45 mins to drill out both bolts, got them both out perfect with out damaging the threads on the yoke i sold too
Also got the lock unit now installed in the 954 yoke with the 954' HISS sensor also fitted, had to remove the plastic from the Firestorm lock barrel, but no longer need it now its covered by the HISS unit
had a bit of a moment when i was drilling.... had one knee on the side of the yoke, drilling away... suddenly it grips. and spins the yoke round on the axis pivot point that was my knee and twatted my knee on the other leg! OUCH!!!!!
then.....
i jumped back drill bit shatterd, drills still going and nearly shoved it through my leg when I fell backwards :eek2 :eek2 :eek2 :eek2
See, that's your Honda security, that is. If your bike gets stolen, look for the bloke with a busted kneecap and a hole drilled in his leg, down Casualty. That'll be him.
seb421
Post by seb421 »
HAHA yeh i learnt quickly from that one, got some assistance in the form of my dads feet after i had stopped bouncing round the garage swearing at everything in sight.
