I've recently bought a 9k mile 1997 firestorm and after a ride out I turned the bike off to start it again and battery was nearly flat. Managed to get her going again after a jump start. Bought new battery to solve the problem. Happened again today in Bridlington and got rescue out as it went again. Been told it might be a rectifier problem. When running it's trickle charging just over 12v. Took rectifier off to clean it as connections were rusty and poor earth. Anyone had anything similar. Don't want to buy new one if it's not needed.
Thanks
Craig
Rectifier?
Re: Rectifier?
Hey Bobby, welcome to the forum. The rectifier is a known weak spot on the storm. If its the old unfinned type you have it sounds like its fecked.
I have done the R1 mod on mine which is talked about here often. Just do a search on the forum. Or have a look here http://vtr1000f.wickidnet.com/
Jazz
Jazz
Everything good is bad
Everything bad is good
- benny hedges
Re: Rectifier?
or get the later finned and much bigger r/r off a cb1100 or similar, fits the original plug.
make sure you clean them connectors up.
get it sorted asap - apparently when the r/r & battery fails & you keep trying to start it on a low charge, it will kick back & crouton up the sprags in the starter clutch.
Re: Rectifier?
Thanks for the advice, I'll sort the mod out or at least get something bigger with fins with possibly same plug fitting. Will any year r1 or r6 fit?
- Contact:
Re: Rectifier?
I think you will need to cut some wires to fit an r6 / r1 rectifier
Re: Rectifier?
just seen this one with same or similar plug connections if anyone knows if it will fit. thanks
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
- benny hedges
Re: Rectifier?
yep that will fit the plug and will most probably line up with the mounting holes as well
Re: Rectifier?
Thanks,
just ordered it. thought it might be ok as its got fins and straight fit plug. am poor at electrics. how do i load my bike pics on here?
- benny hedges
Re: Rectifier?
read the how to in the computer help section - easy once u get the hang of it
it's like falling off a bike.
or is that falling off a log?? & riding a bike??
