help needed with bike cutting out
mattieboy
Post by mattieboy »
hi, just a quick one, ive got a 1998 storm, ive just cleaned the carbs and put her back together. once all parts were back on i did the only other thing to do {Start the old girl} she fired up but as soon as i went to put some revs on she cutout. has anyone else had this problem or know what ive done?
Please help. the suns out and im stuck in the garage,
Kindest
Matt
Re: help needed with bike cutting out
you've put the vacuum line on the wrong stub on the fuel tap :clap:
don't worry, you're not the first!
mattieboy
Post by mattieboy »
know im prob been thick but any idea which ones i need to put where?
matt
First up, what was the problem (if any) that prompted you to take of and clean up the carbs?
That will help any of the more fuelling expert residents narrow down things. Though working backwards from where you are now - did you connect the tank fuel and vacuum hoses back correctly (& without nipping anything) - plus turn the tap back on?
theres a 6mm vent pipe that heads off down toward the swing arm, and a 6mm vacuum pipe that comes from the rear cyl inlet stub.
swap them over.
i havent got a fuel tap on mine now so i cant show a pic - but if you search fuel tap theres been loads of posts and pics of the exact same problem.
just swap them over and it will run. easily done, easily fixed. :thumbup:
mattieboy
Post by mattieboy »
thanks very much just putting the pipes on now and will repoet back soon
Thanks again
Matt
well seeing as last post was hrs ago, i'm assuming it's fixed and on the road lol :clap:
mattieboy
Post by mattieboy »
thanks very much for all your help, seems to have worked. goin to take her out for a spin tomorrow morning see how she goes
again thanks for ya help
Matt
