This was intermittant at first but has got progressively worse. When I went on long run in the rain a while back it was running dog rough and felt like down to one cylinder (if that) was struggling along cutting out/rough running, as it dried out it got better.
Also, after pulling a wheelie (off road of course
Carbs have been cleaned and did fuel better after this but same problem occurring.
Last 2 weekends out on it its starting to cut out with a mechanical 'crack' starter noise at low speed (mainly on overrun or when blipping it)
Its now doing all time making it unrideable, starts fine, but then blip throttle and thump/crack cuts out (sounds starter motor area)
Whipped off starter teeth look ok - spark mate gonna check it for me tommorow
Could this be a sprag gear problem cutting out engine ?
any help appreciated, bummer was after another month of decent weather/riding before the winter rot sets in !
Have ordered another starter solenoid and kill switch (ebay) to try those out, starter being checked tommorow, should I strip flywheel cover and have at this sprag clutch or do i need remover ?
cheers
Ian
