Disk bolts ( New or re use? )
Styler4077
Post by Styler4077 »
I'd like to replace all my disk bolts as per the manual.
My question is do you guys bother or use the same ones with new locktite applied?
Or can you use any other bolts. HT one of course.
"Only one life, so live it and ride a motorcycle"
Re: Disk bolts ( New or re use? )
I used old ones with new loctite, but you could fit any high tensile bolts if you wanted [with loctite].
Companies like pro-bolt do kits, but are expensive.
If you want to go mad you could fit titanium bolts and justify them bas the have better corrosion resistance so will look good for much longer.
I found a mountain bike supplier Tibolts.co.uk who does them cheaper than pro-bolt, as I need to replace the corroded bolts that hold the Calipers together, but I haven't opened my wallet yet.
Twinpotter
Post by Twinpotter »
Styler4077 wrote:do you guys bother or use the same ones with new locktite applied?
Yep, it's all about the thread lock; as long as you wire brush the dried thread lock off for a nice clean thread then apply a fresh bead to each before refitting, job done.
Starts with a R. Rrrrrrrr. Motorbike!
Styler4077
Anyone found a supplier of Titanium or Stainless Steel bolts at a reasonable cost?
Checked with Honda they want £2.88 each £35 a set...... :eek2 standard rusty parts not SS
Dave Silver £1.40 ish each.
Steve
vtrbarmy
Post by vtrbarmy »
Re-use as others have said, just make suer you use the blue loctite, not red - just in case you ever want to take them off again.
I buffed mine up on a polishing machine, been fine since, no problem.
Styler4077 wrote:Anyone found a supplier of Titanium or Stainless Steel bolts at a reasonable cost?
Steve
[M6, 1mm pitch, x 17mm...12 off]
Pro-bolt want £87 for a set of Ti bolts , or £52 for SS
TiBolts.co.uk want £47 for Ti, but they are 20mm long so have to work out if you need to cut, or if there is enough depth in the thread.
so the David Silver price looks prety good, but as VTRbarmy suggested, for that money I would have a go at polishing the ones you have
Styler4077
OK I'll look for "Blue" loctite and polish my bolts on a buffing machine easier than my nuts (so I've been told :D )
Need to find at least 4 replacement bolts as previous owner has knackered them.
I have a 20mm long bolt and it fits OK thread depth looks to be over 25mm on my bike
Steve
