no tabs
uptonpark64
no tabs
Post by uptonpark64 »
any advice on my rear fairing round the seat, there should be 2 tabs underneath but iv'e got one broke
and one missing, firstly are they important and secondly, any way to fix it without 1.superglue or 2. plastic ties
Re: no tabs
The underneath ones don't seem to matter, but the ones on top are quite important.
It's often where a well-meaning mate has helped to bump-start the bike, and pushes on that plastic-
it's far too delicate to take that kind of force, much like myself.
Slap some gaffer tape round it, you can't see it from where you sit so it doesn't matter.
:D
SWAGGER
Re: no tabs
Post by SWAGGER »
If the tab has broken on the body panel you could build a very professional repair using 'Plastech' products. It's not actually a structural fixing point so as was said you could dog it.
The force is strong with this one!!!
Yamaha XT1200Z Super Tenere
Yamaha FJR1300
Re: no tabs
Like Tony said, woudn't worry about it and the fiddly little plastic screws that go with em - that includes the ones that are used on the inside of the fairing near the radiators.
bigrich
Re: no tabs
Post by bigrich »
one of mine snapped off so i drilled a very small hole in the plastics and undertray and cable tie it, barely noticaeable
Honda Britain 50th anniversary storm (26 of 50)
Carbon Hugger
Carbon undertray
Carbon LED indicators
Clear LED rear light
Shark Skinz Bellypan
Harris RearSets
Ohlins Steering Damper
Proflex suspension
Remus high level carbon cans/micron stubbys
uptonpark64
Re: no tabs
thanks lads, one less thing to worry about!
SWAGGER
Re: no tabs
Post by SWAGGER »
Seriously, if you have any kind of ability re airfix modelling give the Plastech and ABS plastic sheeting a go. You can achieve brilliant results.
Yamaha FJR1300
