Raising the rear
Buckers
Raising the rear
Post by Buckers »
Howdo
I've heard about raising the rear shock with a spacer to improve the storm's handling. I saw this on ebay
http://cgi.ebay.co.uk/VTR1000-VTR-1000- ... 660wt_1139
Would this do the job as advertised? Any help appreciated. And has anyone done the mod - is it good? I've got a standard bike and I'm intending to keep it that way suspension wise (£££'s....)
Re: Raising the rear
yes it will do the job and it does make a difference, but that spacer on ebay is only 3mm thick so you might want to buy 2.
or just make your own.
get a 40x25mm piece of steel or ally, drill a 10mm hole in the centre, then hacksaw the hole to the edge as in the ebay spacer.
a 5mm spacer will raise the rear by about 15mm.
it goes under the rear shock mount under the seat at the back of the tank - just loosen the 17mm nut and pull the bike over on the sidestand, pop the spacer in & tighten the nut up again.
also helps to drop the forks through the yokes and bars 5-10mm, so they stick up a little through the bars.
you need to remove the retaining clips to do this - and don't undo the pinch bolts too much or the forks will drop right through lol, make sure they are good & tight before going on the road!
what size rear tyre do you have on the bike btw - and brand / type...
it will help the bike turn in faster and hold a tighter line in curves.
Buckers
Post by Buckers »
Thanks benny
It's on dunlop roadsmarts, standard sizes and wheels from the manual
the storm does feel very nose up compared to my cbr, even the hornet I had. It gives that feeling of having to 'push' it up a turn.
well it won't when you raise the back end, it should tip in fine.
what notch have you got the shock on? im 14st and use 2nd notch - when i got the bike it was on the 5th, hardest setting and it was like riding a pogo stick.
if you drop the forks, dont drop them too much or it gets a bit twitchy at low speed.
just be carefull parking tho as the bike will lean forward a bit more aggressively and be a bit more upright on the prop stand.
re the tyres, was just wondering if you'd put a 190 on the back or squared it off....
standard tyres are 120 & 180.
you might want to think about putting some firmer springs in the forks.... i have wirth progressive springs from wemoto in mine and it made a lot of difference to the handling.
Stratman
Post by Stratman »
TBH I have found that dropping the yokes about 5 mm, using heavier fork oil and changing the fork springs for some meatier ones worked a treat. I wouldn't bother with the spacer IMHO
Buckers
Post by Buckers »
I weigh 10 3/4 stone, and have the rear shock set as standard. 180 and 120 tyres, still newish and have a nice profile. They are great for commuting now its cold and wet. They handled a warm cadwell track day too and I've no complaints - all the grip, it was the suspension and brakes that couldn't cope with going any faster.
I'm not overkeen on dropping the forks if it can make it a touch twitchy because I do an urban commute - often doing naughty flick in and outs at low speed.
But I do plan to track her in spring and autumn (and hire sportsbikes in summer when there's a chance of a drier day (!), so an extra bit of sportiness wouldn't go amiss :D
At less than 11stone, the back shock will be too hard even on setting 1, but and the front forks will still be too soft! [figure that out :confused ].
3mm spacer with the shock on lowest preload will be a good start, and you will feel it turn in better. I would get the froks upgraded with stiffer springs and oil before you drop them too much. Until they are fixed, there is a small risk of headshake if you drop the front [or raise the rear] too much. so 3mm on the rear will be fine now, but once you have the forks sorted you can then go for more to get the turn in / stability compromise that works for you.
As benny said, you can make your own with some good sized 1mm washers, then you add 1 at a time till you like the result.
Tony's tips # 7:
If you're dropping the yokes on the forks, only undo one side at a time.
That way it can't fall all the way down, and you don't have to realign the forks/stem/wheel.
By rotating the fork leg you can move it up or down the required amount easily. Just twist it a bit one way, then a bit the other while adding pressure in the required direction.
