digital clocks
denisblackvtr
digital clocks
Post by denisblackvtr »
Can anyone tell me if Pikeman is still a member? If not does anyone know of a set of digital clocks (speedo) that are a relatively straight forward swap. The reason i ask is because pikeman had r6 clocks fitted to his firestorm and i think they looked good so fancied something similar myself. Any help gratefully appreciated. Den
GAS GRASS OR ASS NOBODY RIDES FREE
mik_str
Re: digital clocks
Post by mik_str »
SP clocks are said to be a relatively straightforward swap. Depending on the year of your storm, you either have to change the temp sensing probe (if a pre-2001 with analog temp gauge) or the fuel sending unit if using a 2001 and later model).
I have a 99 and plan to swap the stock cluster for an SP unit in the coming weeks.....
geodude
Re: digital clocks
Post by geodude »
mik_str wrote:SP clocks are said to be a relatively straightforward swap. Depending on the year of your storm, you either have to change the temp sensing probe (if a pre-2001 with analog temp gauge) or the fuel sending unit if using a 2001 and later model).
Any chance you could document the process. Would make for a good thread me thinks :)
denisblackvtr
Re: digital clocks
Cheers mik, as geodude says let us know how you get on.
mik_str
Re: digital clocks
Post by mik_str »
I am anything but an electroncs whiz.... I suggest you have a look at the Superhawk forum as the info has been posted there (is what I will be using to guide me through it)...
good luck!
