not a firestorm question, just a general engine one!
bigrich
Post by bigrich »
A mate of mine has bought a r6 track bike, he has had it running for 5 minutes and water has started pissing out the coolant expansion (think thats what he said) - any one had experience of something like this? could it be the cylinder head?
Honda Britain 50th anniversary storm (26 of 50)
Carbon Hugger
Carbon undertray
Carbon LED indicators
Clear LED rear light
Shark Skinz Bellypan
Harris RearSets
Ohlins Steering Damper
Proflex suspension
Remus high level carbon cans/micron stubbys
alec
Re: not a firestorm question, just a general engine one!
Post by alec »
had this on a car once turned out to be the thermostat, do bikes have thermostats?
bigrich
Post by bigrich »
think i do! ill let him know, i had a thermostat go on my car once and that then allowed the head gasket to go, bugger!
Carbon Hugger
Carbon undertray
Harris RearSets
Proflex suspension
marravtr
Post by marravtr »
if its just a track bike it might have a manual switch for the fan, ive bought a couple of track bikes in the past and both had this done?
Let it cool, and try again.
I fit's the cyl head gasket, then it'll start to overflow again immediately, even when cold.
If it only does it when hot, then it's the coolant circuit.
Check the coolant bottle and pressure cap for oil, and the oil for coolant.
might be that it has no proper coolant, just tapwater.
proper coolant has a much higher boiling point whereas tapwater will be bubbling its butt off at a normal running temp of 105c ish.
roll up a taper of bog roll and soak some coolant up, see what colour it is & what smell...
pukka bike coolant will most probably be bright orange or blue or summat.
bigrich
Post by bigrich »
cheers lads have passed on the info - will let you know what the outcome is
Carbon Hugger
Carbon undertray
Harris RearSets
Proflex suspension
