Swampy
Post by Swampy »
These lambda kits are pretty dear $270us each...guessing the sensors are beyond a multimeters capability?
I bought mine for much less than that, proper Bosch sensors, too.
I can't recall where from now, but it's on the thread.
The display is just a bare circuit board, so you will have to make a waterproof housing.
They will fit into the upper surface of the side panel, but I made a little carbon panel to sit near the speedo.
If you want to go cheap, just use one display panel and a switch to select which one to read.
Swampy
Post by Swampy »
tony.mon wrote: Thu Feb 14, 2019 7:52 pm I bought mine for much less than that, proper Bosch sensors, too.
Cheers dude, surfing your mod
Swampy
Post by Swampy »
Swampy wrote: Thu Feb 14, 2019 9:40 pm
Yeah mate, I'm sold on the constant display and flow control over mains...the ones I was looking at were boy racer dash style
Put it in the van. :D
Had to drop the van off at the dealers so very convenient to have a second mode of transport in the back to get to work. ... but will need to make sure I wash all crap off it as there will still be salt on the roads and don't want that 1976 chrome to start rusting again
KermitLeFrog
Post by KermitLeFrog »
Got the tank back on, now ready to roll it out and start it up.
Am I the only one who has real problems getting the connections on the fuel tap? PITA job.
KermitLeFrog wrote: Mon Feb 18, 2019 10:45 am Got the tank back on, now ready to roll it out and start it up.
No your not, it is a PITA...If we had three hands it would be easier, I doubt extra fingers would help much & I wouldn't know as I have the correct number on each hand...
I do use a wooden stick/tank prop to hold the front up tho that makes it a bit easier...
You could always get quick release joints for the pipes...
https://www.ebay.co.uk/sch/i.html?_from ... acat=10063
KermitLeFrog
MacV2 wrote: Mon Feb 18, 2019 11:02 am
QR for the fuel lines is a REALLY good idea. Ordered....
norry rc8
Post by norry rc8 »
managed to get out a run late Sunday afternoon. looking for a road I went on years ago (night shift cutting trees on railway) it is lick a big set of jumps. :eek2 :biggrin :thumbup:
not found it yet ,but had a good run (130 miles) looking for it.
cleaned all the winter crap and oil off the pegaso, give it a service and its still running sweet.
the blue one i can do nothing with because im at the stage i hate, the bit that other people have to do for me like making up new graphics for the tank, which cant go on until the painter paints it :roll: :roll: :roll: :roll: ..
ggggggrrrrrrrrrrrrrrrr
norry rc8 wrote: Mon Feb 18, 2019 5:56 pm managed to get out a run late Sunday afternoon. looking for a road I went on years ago (night shift cutting trees on railway) it is lick a big set of jumps. :eek2 :biggrin :thumbup:
are you sure it wasn't a field
Set to on stripping the rear end off Big Bird to check the linkage...
Good news all moving freely & nothing seized... :thumbup:
Changed the small end of dog bone bearing as it was a bit crunchy... Other than that all good so cleaned up lashings of Kluba & put it mostly back together...
The carbs are seized solid so that needs sorting...
Bad news my feking withered arm is killing me now... :thumbdown:
norry rc8
Post by norry rc8 »
AMCQ46 wrote: Tue Feb 19, 2019 12:42 pm
it had tar on it ?
I will keep looking :D
KermitLeFrog wrote: Mon Feb 18, 2019 11:16 am
I agree that is a good idea :D
Is it 8mm release joints we need for our fuel lines as in Mac's link :?: And is it 10mm hose clips we need like these:- clips https://www.ebay.co.uk/itm/DOUBLE-WIRE- ... :rk:6:pf:0
Yes, 8mm will flow fuel faster than your bike will drink it.
