Page 1329 of 1497
Posted: Tue Sep 01, 2020 5:07 pm
by nigelrb
MacV2 wrote: ↑Tue Sep 01, 2020 3:57 pm
As promised I attacked Rusty the Storm with hammers, chisles, drills, flames & lots of plus gas...
I will not be defeated...
Exactly the right attitude. Think of it as having been presented an entrepreneurial opportunity!!
Posted: Tue Sep 01, 2020 6:25 pm
by Dickiebig
I won !
It turned over by hand easy enough, might stick a set of manuals on it & see if it starts, but having put a battery on it, it lit up ok & shows 37500mls ... is it worth the effort to save ?
All the body work is off despite feking pro bolt bl**dy fixings on the fairing & mudguard... 3 came out easy...Thanks plus gas. 1 was drilled. 3 on the mud guard also saw the vengence of the drill...
Round two on the sump bolt..victory is mine also killed the oil filtter with a screw driver, even that was so rusty the removal tool just rounded it off...
Oil came out with no major bits of metal fillings in but was a bit milky, prob just condensation...
Took the rusty as fek rack off & the fitting kit came out easy...
Thats enough for today...
Well done that man. Crack on!!
Posted: Wed Sep 02, 2020 9:57 am
by Duffy1964
Well done Macster, bet you grazed a few knuckles fighting rusty.
Posted: Wed Sep 02, 2020 4:46 pm
by MacV2
Duffy1964 wrote: ↑Wed Sep 02, 2020 9:57 am
Funnily enough no...Best get me tetnus up to date tho...
The not fractured but really is fractured finger is a bit sore, then muppet that I am, I shut the large double glazed door on the extension on me index finger on the same hand...Lef thand so all good for
Could be worse..one of the other techs has apparently written off one of the new vans today...
Mines only got 1600 miles on it, his one has got to be there or thereabouts...
Posted: Wed Sep 02, 2020 7:34 pm
by nigelrb
MacV2 wrote: ↑Wed Sep 02, 2020 4:46 pm
. . . The not fractured but really is fractured finger is a bit sore, then muppet that I am, I shut the large double glazed door on the extension on me index finger . . .
So you're now relying on the 'Marquez excuse' to gain empathy?
Posted: Thu Sep 03, 2020 8:28 am
by tony.mon
Didn't know you even had an extension on your index finger.
Useful for getting the retaining clip on when changing headlight bulbs.
Or was it for deep nasal action?
Posted: Thu Sep 03, 2020 5:42 pm
by MacV2
tony.mon wrote: ↑Thu Sep 03, 2020 8:28 am
It has many probing abilities...
Posted: Thu Sep 03, 2020 7:15 pm
by tony.mon
MacV2 wrote: ↑Thu Sep 03, 2020 5:42 pm
I'm only saying "scratch and sniff" once, then dropping the subject......it's dead to me now.
Posted: Fri Sep 04, 2020 1:40 pm
by nigelrb
Had a good 'old man' ride today, which means I was prepared to take it easy and sit behind the little amount of traffic rather than race past it.
Great on the roads (UK) with schools having returned.
Posted: Sat Sep 05, 2020 7:16 pm
by Pete.L
Took a test run up
to Reyadar today and on up to Elan Reservoir. Lovely to see it in the sunshine
Thought I’d better take me Bro’s too as I’d forgot to invite them Stormin Wales
Posted: Sat Sep 05, 2020 8:54 pm
by tony.mon
I did the petseal regime on the tank of the wife's SL125.
It was impressive, and removed 15 years of neglect and rust. I need to wait a week for it to fully set and garden, so will take it to the painter the sat after the Wales run.
A slight annoyance, he pushed a shallow dent out if the tank side a couple if weeks back, but used a lever through the filler neck, as you have to. He disturbed the filler neck levering on it, and so even with the filler cap on it still allows the acids and washes to leak out, due to the neck surface not being flat. I tidied it up as best I could, maybe the painter can flatten it with filler¯\_( ͠° ͟ʖ °͠ )_/¯
I have a new filler cap and gasket to use, but I hope it doesn't leak fuel after it's been painted.
If it does, I will try the anti slosh foam in the tank, and never fill it completely, and hope that will be enough.
To be honest, with 4 1/2" drum brakes it won't decelerate fast enough to cause the fuel to slosh anyway......and it certainly won't accelerate fast enough, either.
Fingers crossed.
I thought about cleaning the Tuono, ready for Wales, but as it's due to rain throughout, won't bother. Might dubbin my leathers and boots tomorrow, instead.
Old school styleee
Posted: Sat Sep 05, 2020 9:07 pm
by MacV2
Gave Nue Red some luvin, ready for next week.
Oil N fillter, top up the scott oiler, gave the callipers a clean & checked the pads.
Farted around with a Bagster universal harness but I couldn't get it to sit right, bag when fitted is too far back. Gave up I will stick to the magnetic bag.
As Tony said we will prob get some rain so didn't bother washing it...
I might show it a rag with some polish on it on Thursday then wash Wales off it next Monday...
Posted: Sun Sep 06, 2020 12:37 pm
by sirch345
Pete.L wrote: ↑Sat Sep 05, 2020 7:16 pm
Took a test run up
Lovely to be out on your bike when the weather is good
Good to see the photo's Pete
Posted: Mon Sep 07, 2020 3:36 pm
by Choldy
So not today but at the weekend I removed the vfr800 bars and switched back to standard bars, added bar end mirrors so I can see more than my shoulders and removed standard mirrors and put in blanking plates
Posted: Mon Sep 07, 2020 3:51 pm
by nigelrb
I can't use bar end mirrors because the bikes won't fit through my front door!
