Have I done everything needed for a carb clean?
Karl_h
Post by Karl_h »
Further to my other posts I've got the carbs off and stripped the bowls.
Inside the bowls I've removed the 2 flat head screws the biggest of which is what I believe to be a jet?
The other is smaller and sits in the 8mm bolt headed jet?
I've also removed this jet I've cleaned all these and jetted with compressed air.
All this has been done with the carbs upside down and I've also jetted air down all the orifices that I've removed things from.
So I'm left with the needles, which I presume are lurking down the holes and one smooth, fairly long brass fitting next to the two I have removed. I've directed air down the small hole in the top of this fitting.
Is there anything else I should do?
Once again thanks for any help guys!
