alec
Posts: 681 Joined: Fri Jan 21, 2011 3:36 pm
Post
by alec » Mon Feb 21, 2011 12:42 pm
Hi can anyone tell me if this is the right place to fit the brass adaptor for permanent fixing for the carb balancing, i have circled where i think it is, this is looking in from the right hand side of the bike (when sitting on it). also which pipe is the one i need to fit the T piece in that goes to the tank.
cheers alec
98% of all Harleys ever sold are still on the road. The other 2% made it home
Jazzscot
Posts: 1316 Joined: Mon Aug 24, 2009 8:42 pm
Post
by Jazzscot » Mon Feb 21, 2011 1:18 pm
Yip thats the one mate. You need to T the smallest pipe that comes off your tank (that's the vac pipe).
Jazz
Everything good is bad
Everything bad is good
alec
Post
by alec » Mon Feb 21, 2011 1:35 pm
Jazzscot wrote: Yip thats the one mate. You need to T the smallest pipe that comes off your tank (that's the vac pipe).
Jazz
thanks mate is that the one that goes to the rear of the fuel tap or the one under the tank ? cause there dont look much between them,
Posts: 7895 Joined: Sat Feb 11, 2006 2:43 pm
Post
by Wicky » Mon Feb 21, 2011 1:36 pm
Get 5mm ID vacuum hose - plenty of metre length silicone tube on fleabay.
Posts: 22404 Joined: Mon Aug 25, 2003 10:35 pm
Post
by sirch345 » Mon Feb 21, 2011 2:00 pm
alec wrote: .
Alec, yes, T into the vacuum pipe that goes to the rear of the fuel tap for the rear connection. The one under the tank is only a drain pipe.
alec
Post
by alec » Mon Feb 21, 2011 2:10 pm
sirch345 wrote: alec wrote: .
Thanks Chris,
its appreciated mate
alec
