carbs spitting back
carbs spitting back
is this normal when riding slow with low revs i can feel and here the carbs spitting back .its like a miss fire .
its a bit disconcerting when going round a round about in the wet :oops:
pinkyfloyd
Re: carbs spitting back
Post by pinkyfloyd »
Mine pops and farts away when its decelerating using engine braking. sounds great fun!
They all do it, stop worrying.
Upping tickover helps. ignition advancer also helps but makes it run a bit hotter.
thank you for putting my mind at ease :thumbup:
pinkyfloyd
They are standard cans. They only really do it from slowing down at high revs. I like it. It scares kids and old folks look around to make sure the devils not behind them.
KneeWobblers wrote:
pinkyfloyd wrote:Mine pops and farts away when its decelerating using engine braking. sounds great fun!
Your cans are sucking air in at the joints, ie extra oxygen is reigniting the gasses, make sure all is air tight at the joins to reduce the overun pop and bang.
either that or left a vacuum hose off ;)
every honda ive had with race cans has always pop bang pop bang on the over run the storm is no exception
to this :D
