Re: Tyres......
- denisblackvtr
Re: Tyres......
It will effectivley make your front wheel 12mm smaller. IE: 120-40%=72mm, 120-30%=84mm. This is how i believe you work out the sidewall height, (the aspect ratio). So theoretically it should help speed up the steering, but i also think it makes the sidewall less flexible. Hope this helps. Den
GAS GRASS OR ASS NOBODY RIDES FREE
Re: Tyres......
Tried a 165/70 with a 180/55 on a 748 once turn in was pretty impressive but the suspension is a lot stiffer on that bike, 160 might make the front a bit skittish?
Due to cutbacks the light at the end of the tunnel has been switched off!
- denisblackvtr
Re: Tyres......
I'm surprised it turned at all with a tyre almost the same width as the rearWalenut wrote:Tried a 165/70 with a 180/55 on a 748 once turn in was pretty impressive but the suspension is a lot stiffer on that bike, 160 might make the front a bit skittish?
front tyre. Den
Re: Tyres......
Must get mt dyslexia sorted.
