2 out of 4 not bad 50% i guess !!!
arnie
Post by arnie »
Well on removal of headers I had 2 studs break off out of 4 , 50% not bad I suppose, luckily there is the main body of the 8mm bit still let so hoping I can warm it up a bit and get them, if not then it will drilled and Helicoiled i guess ! :?
Re: 2 out of 4 not bad 50% i guess !!!
i had to have my front studs drilled and have an insert put in as they snapped . jobs a good un now i can remove the headers when needed
