Is this LED flasher relay suitable?
Pantaloonie
Post by Pantaloonie »
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0306899456
This looks like the correct one to me, is it? :confused
Re: Is this LED flasher relay suitable?
No idea from the description, or should I say, lack of it....
Suggest that you just fit a resistor in series with each indicator, mimicking the load same as a standard one.
Alternatively a specific relay to replace your standard one which is design to cope with LED indicators.
That way you're guaranteed to get a proper flash rate.
Pantaloonie
Thanks Tony, got resistors fitted already by the previous owner, but the wiring is a mess and needs regular poking as I never know whether they're gonna flash fast or slow. I just want to rip the whole mess out and replace the relay.
From the little I can see in the pic, it seems to have the correct connector - for a tenner I think I'll give it a punt....
I've fitted twice those aftermarket round relays and they quickly shake themselves to bits - and that's despite trying to isolate them from the worst the storm can offer. Fitted second-hand OEM one from another Honda model (same model no. check Ron Ayers reverse part function) and been fine since.
