Fuel leak
Fez Parker
Fuel leak
Post by Fez Parker »
Hi, I have a 97 Storm with a rather perculiar problem, there is a leak coming from the base of the fuel tap under the tank it comes out from a very small hole in a round piece that sticks out of the bottom of the tap, not sure if is meant to be attached to a hose of some description, but the percularity lies in that it only leaks just after the engine has been run and then stops after a few minutes, it doesnt appear to leak whilst the engine is running though, any ideas? Fez :confused
Re: Fuel leak
You might want to try checking you have all the hoses attached correctly esp if the tank has been off at any time and invest in a fuel tap rebuild/repair kit. http://www.nrp-carbs.co.uk/honda_fuel_t ... ir_kit.htm
tinysmall
Fuel leak
Post by tinysmall »
Are you the chap that was down at loomies the other day?
Never mind, just seen your other post :)
simo
Re: Fuel leak
Post by simo »
The round bit you refer to is a breather. Sounds like the diaphram in the tap is knacked.
Theres A Hare in The Turnips.
Re: Fuel leak
simo wrote:The round bit you refer to is a breather. Sounds like the diaphram in the tap is knacked.
That's exactly what I was going to say. You need to get a diaphragm replacement kit ASAP.
Wicky has recommended a supplier in his post.
Fez Parker
Re: Fuel leak
Wicky wrote:You might want to try checking you have all the hoses attached correctly esp if the tank has been off at any time and invest in a fuel tap rebuild/repair kit. http://www.nrp-carbs.co.uk/honda_fuel_t ... ir_kit.htm
Thanks for the info I will chase that up asap :D
Fez Parker
Re: Fuel leak
Thanks for your help guys, I will chase up that kit and get it fixed ASAP :D
