and I'm pleased with the service and quality. They are a hell of a lot lighter than the originals and sound awesome. "LAF" (Loud as Feck)
I like a bit of noise coming out especially when I'm commuting into London and going down "corridors". I've had to buy the set of baffles which are available
from Danmoto for this type of can (GP Extreme) these inserts are put in the can's inlet where the link pipe is connected to and not the outlet of the can like many others are.
When cruising in traffic the cans have a big grunt still, as if I hadn't any baffles at all.
The thing is, is that they're still too loud I think, for road use although I haven't had them db tested yet..M.O.T still to come up. I just want the cans to be toned down
a little bit more and now I'm thinkin in either putting some sort of wire mesh (brillo pad) of some sort to baffle them a bit more.Or...buy longer baffle inserts.
Anyone got any opinions on this? What d'you guys think of the brillo pad "scheme" will they last? or would a longer baffle do the trick?
After all I don't want my Storm sounding like a "WET FART" as my mechanic put it ....
I use ear plugs always and even with my plugs all the way sown my lugs there Loud. Not sure whether I'd survive a long haul without going deaf or crazy, although
the faster I go the noise does seem to ease off a bit probably due to higher revs etc.
Verdict: great buy but just a bit too loud for normal road use.
Any suggestions fellas? I'd be grateful
