hugger issue!
BIGANDYREDVTR
hugger issue!
Post by BIGANDYREDVTR »
The rear hugger fitted on my storm is chafing on the tyre once the tyres get a bit of heat into them!
On closer inspection hugger seems to be fitted over original chain guard!!!!
That cant be right can it?????
:confused
simo
Re: hugger issue!
Post by simo »
Hi, I have a Pyramid hugger on my bike with the original chain guard fitted over the top. I use Dunlop tyres, D208 and 209's and they have been very close to the hugger but the Roadsmart i have just put on is miles away. After measuring with a big set of callipers its 6mm narrower. Don't suppose any of this helps you lol
Theres A Hare in The Turnips.
Re: hugger issue!
i tried a 190 on mine last year and it was just catching the hugger slightly on the chainguard side.
i lifted it a bit at the back with small brackets & it worked ok, no more rubbing, but had already worn a groove in it.
