Anyone changed the rear spring only?
Which one did you guys use?
Fixed engine is pure happiness..............
rear spring Same shock
- Stormer Dave
- benny hedges
Re: rear spring Same shock
yes mate i fitted a yacugar progressive rear spring from ftr suspension.... about 80 notes.
if you are local nip down with your shock and they will fit the spring for free.
jolly nice chaps too 01284 752102
no more hopping back end, definately feels like it's digging in better.
Dave, I fitted a Maxton spring, it's rated to suit my own body weight. IMO it's definitely an improvement over the standard spring, the shock now moves up and down
As with Benny's recommendation, the guy's at Maxton are also very helpful people too:-
http://www.maxtonsuspension.co.uk/
If you are between 11-14 stone you want a 800lb spring.Faulkners are well cheap .Standard is 925lb and too hard.
