Iridium plugs
Steve97
Iridium plugs
Post by Steve97 »
Have just changed plugs to iridium (expensive) and cant help noticing a distinct "detonation" when shes running, is this normal ? its far more pronounced than the normal NGKs i took out , every thing else is fine no farting banging, runs like a dream, seems to pull stronger and accelerate faster, and i thought it was ok before the change ! just a bit worried that holes will be burned in pistons, or some other such problem,
Thanks fellas
Steve
Animal
Re: Iridium plugs
Post by Animal »
I think you'll find that iridium plugs are a standard fitment for the Firestorm.
Its what the 'i' in dpr9eix stands for.
Nothing to worry about there.
Steve97
Re: Iridium plugs
Post by Steve97 »
Not sure about that Animal, both the original owners manual and the Haynes comic state that the standard plug is NGK DPR9EVX maybe the iridium plug is standard on later models ? mine is a 97, cant put my finger on it mate but something is just not right ! :?
Furrybiker
Re: Iridium plugs
Post by Furrybiker »
Steve97 wrote:Not sure about that Animal, both the original owners manual and the Haynes comic state that the standard plug is NGK DPR9EVX maybe the iridium plug is standard on later models ? mine is a 97, cant put my finger on it mate but something is just not right ! :?
Workshop manual says the same..............
Re: Iridium plugs
Steve97 wrote:Have just changed plugs to iridium (expensive) and cant help noticing a distinct "detonation" when shes running, is this normal ? its far more pronounced than the normal NGKs i took out , every thing else is fine no farting banging, runs like a dream, seems to pull stronger and accelerate faster, and i thought it was ok before the change ! just a bit worried that holes will be burned in pistons, or some other such problem,
Thanks fellas
Steve
If it runs stronger and accelerates faster, just be grateful
If it burns holes in pistons you can fit high comps!
But as the ignition timing is unaltered it won't do that.
Check the plug caps; it's easy to crack the 90 elbow inside the rubber housing when pulling them off.
Animal
Re: Iridium plugs
Post by Animal »
Must admit dont normally bother with manuals for that information, normally go straight to the manufacturer. Check out the link.
http://www.ngkpartfinder.co.uk/mc_searc ... ngine=1000
Re: Iridium plugs
Steve, just to put your mind at rest, I've been using iridium plugs for the last 18,000 miles with no problems yet,
Steve97
Re: Iridium plugs
Post by Steve97 »
Thanks for your help lads, will stick with it for a while, just cant believe the diference!! faster, accelerates harder,
Vibrates a little more, its a bit like having the choke on just a touch, anyway its running really well so will just get on with it.
Oh and one other thing, bet you cant explain this one, changing the plugs has stopped the clutch rattle !!!
Dont you just love this bike !!!
Thanks again
Steve
Re: Iridium plugs
Steve97 wrote:, bet you cant explain this one, changing the plugs has stopped the clutch rattle !!!
Thanks again
Steve
I'll have a go....
Any petrol four-stroke engine runs unevenly, because the crankshaft speeds up as the piston goes down after ignition has occurred.
It then slows down because of internal friction and load until the next ignition/power stroke.
So the lumpiness of a single is because the piston accelerates the crankshaft only once in every to complete crankshaft rotations, and the crankshaft slows down a little during the rest of the cycle.
So this means that the crankshaft is not spinning at a constant rate, speeding up and slowing down as fast as the engine is rotating- up to 10,000 times each minute.
The clutch has a little play where the engagement squares on each clutch plate (or the splined teeth for the metal ones) engage on the clutch basket or centre splines.
That's what rattles.
There can't be no tolerance as in order to operate the clutch plates have to slide sideways with as little friction as possible.
Plugs spark at very specific points in each revolution, and normal plugs aren't quite as exact as Iridium ones, due to a wider area at which the spark can occur, meaning that the spark is more variable. By fractions of a degree, probably, but even so....
By fitting new iridium plugs, the ignition happens in a much more controlled way, at a more exact point in each rotation of the crank. (every rotation, as there's a wasted spark system).
This means less variation in the exact number of degrees before top dead centre the ignition spark (and therefore power pulse) occurs.
less variation means less difference each time round for the power pulse,, and so less rattle.
You can see this for yourself if you use an oscilloscope, and watch the timing marks dancing around in the strobe light.
Easy.......
Steve97
Re: Iridium plugs
Post by Steve97 »
I think we.ll leave it there then Tony......... :wink:
darkember
Re: Iridium plugs
Post by darkember »
Would I be correct in thinking if both plugs look like the one below then the fueling is pretty well spot on?? Light brown tan.
Re: Iridium plugs
looks BIT on the rich side to me that bud.
light tan is more like the colour of a rich tea biscuit
that looks more like a dark chocolate digestive!
whats your air filter like?
btw iridium plugs dont last forever.... change them every 5k at least for best performance/
the one in the pic looks past its best.
darkember
Re: Iridium plugs
Post by darkember »
Just ordered 2 Iridiums & a new filter from wemoto as mine does look a little grubby. Thanks :thumbup:
Re: Iridium plugs
well, taking my own advice, realised ive done over 14k on my plugs :oops: so searched my garage for new ones as i had 2 pairs of brand newies somewhere.
i could only find one of the 4 :Argue 1:
so i had to order some new ones - very cheap & free delivery from here
so at that price, no excuse. if yours are past their best, get them changed!
sorry to urinate on your chips darkember but you couldve had 2 delivered for the price of 1 at wemoto and still saved a few quid lol :lol:
darkember
Re: Iridium plugs
Post by darkember »
benny hedges wrote:well, taking my own advice, realised ive done over 14k on my plugs :oops: so searched my garage for new ones as i had 2 pairs of brand newies somewhere.
I do agree benny, however, for components like that I like to go to a supplier I know & have used before, the extra few quid is worth it. Take a look at the following links you may have seen them before.
http://curezone.com/forums/am.asp?i=1063782
http://www.ngk-sparkplugs.jp/english/te ... index.html
