finish the braced swing arm and fit
replace all bearings
fireblade forks with new springs/oil/bushes/seals
lightened flywheel
new rear shock/upgrade
CLEAN THE ENGINE
paint rear sub frame
that will do for this winter coming
then fit the hc pistons, new rings, shells, clutch & bearing, inspect & repair the gearbox, replace damaged crankcases, fit the new chain & sprox, maybe bin the road fairings and lights etc and fit my track fairings & seat, seeing as i hardly ever use the bike at night anyway and have sold my track bike.
result should be a much quicker, lighter and reliable vtr
new chain & supersprox
brace swingarm (collecting parts as we speak)
send bike to roger d for stage 1 tune
probably getting ahead of myself as the bikes still in bits and so is my body
I plan to swap the engine to see if my spare engine fixes the high frequency vibration and clutch grab.
If that desnt fix it then I am confused, and I will then sell one of the engines.
If it does fix it the currently the plan would then be to strip down the engine that I take out, and put new beaings for the mains and the clutch, but while I am in there I may as well add high comp pistons............but knowing me, I will fit the new engine and then do nothing with the old one
- Re-install Hyperplates (hard anodized and cryogenically treated aluminum clutch plates; significant drop in rotating weight).
- Possibly replace existing front brake combo of EBC 320mm race rotors and Vesrah RJL pads with Braketech Axis Cobra (stainless) 298mm rotors and SRJL pads
- possibly replace standard rear wheel bearings with ceramic hybrid versions (had a set in last year but they failed as a result of a problem with rear wheel, which has since been fixed).
I have a cunning plan, but you'll just have to wait and see......
But having assessed the differences in power between the SP1 engine and the Storm engine, I think there are five or six bhp to be found, and I think I know where it is.
As ever the dyno will tell its story.
And I ran my high comp engine in running around to and from work in the ice and snow, in Kent, this last winter.
Locked up every time I shut the throttle- so I tried not to.....
