I'm concerned because the amount of turn I can make with the bars, results in the damper legs pressing significantly on the radiator hoses. In effect, the turn of the front end is being stopped by the hose, making the turning circle rather ridiculous.
Is this something I should be worried about, or is it normal for conversions of this type? On a standard bike I assume there would be much more clearance as the stanchions are thinner than the damper unit.
I hope I've explained it well enough, not exactly sure of the terms to use.
Can anyone give me peace of mind with this or do I need to figure out how to reform the radiator hoses?
Thanks guys
