what is this likely to be??
Ro88o
Post by Ro88o »
sweet as a nut when cold but a fairly heavy 'annoying' ticking/tapping when hot or up to temp. ccts maybe or valve clearences??? :wtf:
Re: what is this likely to be??
how many miles on the odo????
most likely valve clearances if it gets louder when hot.
warning - a dealer will charge 300+ for shim service, and probably only need to change 2.
something you can easily do in half a day assuming you have a box of shims to hand - i recommend a hotcams shim set 9.82mm diameter for about 70 quid. (300 asst shims)
now that may sound like a lot but you have all the shims you could possibly need and dont need to wait to order them.
and save about £250!
Ro88o
Post by Ro88o »
its done around 24k so thats something i will look into. thanks
stormingjoe
Post by stormingjoe »
Can get individuals from here, http://www.zoomfactory.co.uk/categories.asp?cat=150 and the kits :thumbup:
do you have a link for these benny please
http://www.hotcamsinc.com/ProductInfo.aspx
Tony tip of the day:
Don't google "hotcams" :eek2 :eek2 :eek2 :eek2 :biggrin :biggrin :biggrin :oops: :oops: :oops: :silent: :roll:
i did thats why i asked for a link :oops:
i cant find the 9.82 for the storm :oops:
darkember
Post by darkember »
tony.mon wrote:http://www.hotcamsinc.com/ProductInfo.aspx
It is there just the 5th link down. You perve 8O 8O
Ro88o
Post by Ro88o »
Well I've just bought some manual cct's off Ebay so ill do both jobs at the same time.
stormingjoe
Individuals and kits available at the link I posted!! In the UK as well.
