Going to change the brake lines in the near future. Have seen ther are quite a few types which ones are the best.
Looking to improve the brake performance as they aint that good.And i have changed the pads allready.
Cheers in advance
Thanks
Chris
I have Wezmoto ones on my bike. Cheaper than the above mentioned top brand names but they do the job and do feel a lot better than the original ones I replaced.
Braided S/S lines will belp, but the brakes will still be shite [in my opinion ], getting CBR600 calipers and master cyl from a breakers is the best money you can spend.
your new lines will still work , but your new pads wont fit
I have s/s brake lines (HEL), EBC discs and sintered pads. Brakes are very good now and quite prgressive, which is what I prefer.
However, if you still have sloppy standard forks then better brakes will only mean more diving on braking and more frustration, so both need to be done at the same time from my own experience.
