What fuel is best to use?
Is there any advantages with the more expensive vpower
fuel
will the bike run better or is it all a lot of rubbish
chris
On a standard engine there's no point in putting high octane stuff in, but use main fuel outlets because the fuel turns over faster and is therefore fresher.
If you have cans, jets and filter done, same as above.
If you have an ignition advancer, or high comp pistons, or a full system, I'd run super.
But it's up to you; depends on how you ride, and how you treat the engine and throttle.
Pay your money and take your choice.
Diesel
Butane
Natural gas
Vegetable oil
Ethanol
Or rocket fuel
All of which might make the bike not work.
