Sprocket Nuts
Sprocket Nuts
Just bought some sproket nuts from Pro Bolt ,look a bit ? Anyone any bad experiences, before i replace them,feeling a bit Nervous feeling then weight of them
STAGE 2 Moriwaki Storm Moriwaki Engine Rebuild Pistons Cams Valves etc Moriwaki Air intakes.Air Filter Mod
Full SAMCO race hoses; Lightened Fly Wheel Dynojetted; KN Filter; Moriwaki Exhaust Moriwaki Carbon Belly Pan Titaniam Nuts & Bolt WP R Shock
I have a set too that I took off a bike, not sure if I would trust them even though the major load is shear on the studs because the standard nuts are done up FT on the torque wrench. You find this out when you try and undo the existing steel ones on the carrier. Are they alloy with a heli coil insert? or just alloy? personally I would not fit them as a rear sprocket sliding into the swingarm would leave a fair mess, on the bike too.
Del.
Del.
