Front tyre goes flat
fireman
Post by fireman »
A strange thing keeps happening to me as i go out my bike,
I drive my bike every day and on the odd!! occasion I do give it a bit of welly, everytime I hit 120mph my front tyre goes flat, I then go to the garage and put air in it and its fine to drive after, I dont have to put air into it again unless i crack a 120mph. Is this weird or more sophisticated then what Im thinking is a very strange happening.
My thoughts are that there is a speed rating on this particular tyre which off the top of my head I can't think what it is and once you go past a certain speed it deflates
The tyre has plenty of like left it so have to say WTF is going on
Re: Front tyre goes flat
It's a valve problem.
The spring allows air to escape due to centripetal force.
So all you need to do is replace the valve core and reinflate.
Sorted.
fireman
Post by fireman »
Thanks for that, I didn't have a clue what was going on, now to get it fixed happy days
The best fixes are the cheap ones!
tony.mon wrote:petal force.
sounds like an alliance of rebel flower arrangers.... or a new reality tv show.
terdae tony is pruning his aspidistras.... :roll:
welcome back m8.
and to answer your previous question, yes the sp clutch grabs :think:
& back on topic..... next time you change tyres, check the paint isnt blistered inside the rim.... like a powdery dry rot oxidation on the ally finish
could be the air is seeping under the paint - not unheard of & a trip to the powder coaters will cure it.
The clue here is that it only loses pressure when used at higher speeds.
Poor sealing or a porous casting will leak over time, rather than use or speed-related.
If it's a valve it will hold pressure perfectly for months, but over certain speeds it will leak.
gilson
Post by gilson »
We no longer need this forum. Just tony's email.
On his way to be second only to the great Roger D.
No bike (yet).
