Hello all,
I'm getting the spongy feeling in the front brakes that everybody complains about. Put in EBC green pads, and Galfer steel lines. Brakes are good for about a day, but then go spongy, and I am able to get some air bubbles when I bleed them.
Has anybody heard of the bleeder valve going bad? I'm thinking this because I gave the full caliper assembly a good cleaning and then rode it for a brake check - intending to look for a tiny leak. I had a little brake fluid on the bleeder valve, as I suspected I might, when I was done. Seems wierd that something like that would go bad....
Anybody heard of that?
Brakes again - Bleeder valve leaks?
hm
Two things will help.
Put some plumber's teflon tape on the bleeder and give it a good final bleed. Then tie the lever against the bar tightly. I use a zip tie(as we call it in canada)
Keep the lever pulled in overnight. This will firm up your brakes.
finer points of teflon tape
Hi again - sent a note to your mailbox BTW.
So when you say to zip the lever down, do you mean with the bleeder valves open (so any trapped air can work its way out) or with the valves closed, and everything buttoned up?
