Just been out to scrub in Buddy's 28th rear tyre. Had been zipping along at a fair old pace, glanced down at the clocks to notice everything out. The whole lot dead, no speedo, temp, revs, odo.
Don't know why but my first instinct was to switch the lights off, did that and hey presto everything back on, turn indicators on, clocks on clocks off clocks on clocks off.
Horn did not work, but when ever I pressed it the clocks would die, came home with the lights off. Just been out to have a rummage in the wiring, start him up and everything works like there was never an issue. This sort of electrical fault is a nightmare. No idea what to check other than the whole loom which may have a short in it somewhere.
Has anybody else suffered this? if so perhaps you could help with where to start looking. Is there a common area where the loom might chafe?
Second thing, he seems to have sprung a leak from the clutch cover gasket, easy fix as I have a spare gasket.
Cheers for any advise.
Mike
Electrics n oil!
- Miztaziggy
Electrics n oil!
Have you checked the RR?
Re: Electrics n oil!
Battery, 2nd one on here today,same syptoms,check out "have i been a lucky boy?" thread.
Absolutely Sodding Bloody typical!!!
Check the + – connections on the battery as they can vibrate loose - If you have a pre '01 Storm is it an original unfinned R/R?
- Furrybiker
Welcome to the club! Mine was slightly different, when I braked the clocks sort of came back, indicators did weird things and the horn barely worked. As I got home the headlamp was flickering but not the clock lights..... Through all this the temp gauge was fine!
I hate vehicle electrics
Check your main earth is clean & tight
Cheers for the replies thus far.
R/R was changed 3 years ago so I don't think it will be that, I will check to make sure the correct voltage is reaching the battery just to be on the safe side.
Battery changed 2 years ago, I normally get at least 4/5 years out of batteries and they tend to go in the colder months. But I will definitely check the terminals for tightness.
I hate electrics, sometimes it does not seem to follow logic.
Thanks
Thanks
