Sub frame
Sub frame
My poor subframe is showing signs of rust, ie the paint has peeled off in places revealing bare flesh, is it a hard task to "get it off" so i can hammerite it??? If its beyond mere mortals is the only way with a dremmel in small patches then a fine paint brush.
She told me she was 16.
Re: Sub frame
The subframe is easy to remove.
A digital camera is your friend. Take photos of any wire/cable routing so when you reinstall you can make sure its all in the right place.
Silver 1998 'Storm! That keeps trying to kill me! And is leaving me soon!
Re: Sub frame
Some method would be useful or does one just start taking it apart willy nilly ness.....
Re: Sub frame
Seat off, plastics off, disconnect battery, remove any items from the subframe (Reg/Rec etc), drop undertray off, remove the 4 bolts and job done.
It looks more complicated than it actually is.
Re: Sub frame
Oops!! Forgot to say...
Unattach the exhaust cans from the foot pegs OR just remove the footpegs from the subframe!
Sorry!!
Sorry!!
Re: Sub frame
took mine off yesterday, takes about 5 mins.
one thing to add to above, unplug the double rear light sockets and leave the light in the plastic seat fairing. unplug these first, and work forward, unplugging and photographing as you go. i removed all the leccy boxes and plugged them back into the loom, saves them getting lost/damaged.
once all the bolts are out, the undertray needs a good twist each side about where the pillion pegs fit, and the snap-to-fit bit under the battery was tight on mine, a rubber mallet assisted....
When subjected to an electrical voltage of at least 50 volts, a cat's tail always points toward the north.
Re: Sub frame
Thanks a lot will give this a go with the help of a glass of Gentleman Jack when the family piss me off over christmas and I can have a hour or two with my beloved (bike) in the garage
