Noticed a strange thing earlier. Started the bike up with the lights off. Applied the front brake and there was a glow from the clocks when I applied the brake. Is this normal. Thought about some internal check going on. Or do I have an electrical problem.
Any thoughts..
Clock lights come on when braking
- Rampant Lion
Had: CB125. Benelli 250. Yamaha YDS7.Kawasaki Z400. Kawasaki Z650c. Kawasaki Z650B1. Kawasaki Z1300.Suzuki Bandit 1200. BMW R1100R. TDM 850 (2 off). Suzuki Bandit 1200. BMW R1100RT. Yamaha XT600.
Now: VTR 98 Storm in lovely silver....
Re: Clock lights come on when braking
Sounds like a bad earth somewhere, shouldn't do that as normal
That sounds like a bad earth somewhere, but worth checking out the rear light bulbs filaments first. I have known one filament in a bulb to blow and drop down onto the one below it, causing the power to jump from one circuit to the other as the brake lever is applied which would power up the dash lights,
PS. Oops, it looks like AMcQ and I think alike on the earth bit
- Rampant Lion
Thanks both for that. I will have a look.
As Sirch says, it will be in the tail light or wiring to it. As that is the point where the side lights and brake lights sit close together.
- Rampant Lion
Looks like one of the tail bulbs is the culprit. Thanks for the help.
Ah, a long term prob possibly solved, mines been like that for years will be looking at that tomorrow!
just thought I'd add to this having solved the problem! make sure the connectors are fitted into the bulb holder correctly should go in the underside and NOT directly into the back and back to front like the top one......have even been able to reconnect the front sidelight again too as that doesn't flash with the brakes any more
