Dont know if anyones seen this.
3.5m long
650kg
6728cc
The technical stuff:
2-cylinder; V-type arrangement
Cylinder angle: 45°
Stroke of piston: 176 mm
Boring diameter: 156 mm
Piston capacity: 6728 cm³, 410 cu inches
Compression ratio: 8,7 : 1
Torque: 710Nm 2 1900rpm
3-gear sequential transmission with reverse gear
Front tyres: 38†diameter; 11†width
Rear: 42†diameter; 15†width
Front brakes: twin discs; 310 mm diameter
Rear brakes: one disc; 310 mm diameter
