Luggage advise
Luggage advise
Hi all
Have any of you used Oxford X50 throw over panniers ? I'm going to be using the storm for a few weekends away this year so looking to be able to carry a few bits and bobs. Just wondered how secure they fit ect ?
Cheers Tony
Cheers Tony
- firestorm1997
- Contact:
Re: Luggage advise
I have used Oxford first timers before now without any issues. Strap fits under the seat without any problem,
One thing I would say though is use an old towel or cloth to protect the plastics where the straps fit, This will prevent any damage from them rubbing.
Re: Luggage advise
You'll find the throwovers break the lugs on the side panels unless you either re-inforce them with some alloy strip and rivets or pack a piece of dowel/broomhandle between then to stop them bending inwards and breaking
Re: Luggage advise
Stratman,thanks for the heads up, I'll go and have a look at what you mean if the garage ever gets above freezing again !
Firestorm1997, I did wonder about that
Cheers Tony
Cheers Tony
Re: Luggage advise
those were going to be my comments.........I described the broom handle in another post, but could do some pictures if you cant work it out from wordsStratman wrote:You'll find the throwovers break the lugs on the side panels unless you either re-inforce them with some alloy strip and rivets or pack a piece of dowel/broomhandle between then to stop them bending inwards and breaking
Re: Luggage advise
I used the throw overs for a trip to the Scottish Highlands. They didn't break the tail piece lugs but popped the fittings out.
I used the squidgy matting that came with them but they still managed to mark the paint work. Quite a bit of faffing about with them as well.
I got rid of them in favour of the Ventura system, expensive but works really well. I now have two bags a big and small, they zip together with a combined capacity for enough things for a two or more week tour.
Re: Luggage advise
Animal wrote:Ventura system
I've got Ventura luggage for mine too - well worth the cash! I'll stick on a pic at the weekend.
Re: Luggage advise
mattster wrote:Animal wrote:Ventura system![]()
quick quick theres one on ebay now up for grabs cheap................................http://www.ebay.co.uk/itm/250983942456? ... 1497.l2649
Ooooo too late, i just bought it
Re: Luggage advise
1. By an old seat for a Storm.
2. Drill holes in the pillion part.
3. Bolt an old wooden box on it.
4. Fill it with stuff, ride.
5. Er, that's it, really.
Re: Luggage advice
Or go the whole hog and do what I did a few years ago with a Kappa universal kit. This is from 2005 in Belgium:-
Re: Luggage advise
if you're just using throwovers then I find mine fit very nicely across the front part of the seat, your then sat on the straps and they sit under knees....might be an issue if you're taking a pillion tho.
- firestorm1997
- Contact:
Re: Luggage advice
That actually looks good, didn't think you could buy hard luggage for the Storm. I bought a rack for mine, it's only held on with four bolts and would not be able to carry to much weight,.Stratman wrote:Or go the whole hog and do what I did a few years ago with a Kappa universal kit. This is from 2005 in Belgium:-
Re: Luggage advice
VERY NICE DO YOU HAVE A LINK TO WHERE YOU CAN GET THE KIT FROMStratman wrote:Or go the whole hog and do what I did a few years ago with a Kappa universal kit. This is from 2005 in Belgium:-
Re: Luggage advise
I don't have any links because it was a long while ago. It is/was all Kappa stuff - they sold a "universal kit" which meant quite a bit of head scratching as to what would fit where and some subframe drilling too to munt top brackets, but after that I could get the whole rack assembly on and off in about 20 minutes.
I drilled an extra hole on the side of the rear mudguard for one of the supports. If I can find any other pics I'll post. It worked really well but I don't use it now as I have a system on my TDM which does all the distance work (at 57mpg, you can understand why!)
Try hereto start with.
- agentpineapple
Re: Luggage advise
you could always sell it, it sounds like you already have some buyers
i think it suits the bike really well and it would deffo make wheelies easier.......
