it's an insurance write off due to frame damage.
matey was sitting at a red light, in gear, clutch in, when he got rear ended (not very hard) by a car, causing him to drop the clutch and open the throttle as he fell off the back.... the bike looped, landed upside down, then fell over.
result- smashed screen, most fairing panels cracked, subframe bent. and that's it.
the reason for right-off? one of the little lugs that hold the fairing/clocks subframe onto the headstock has snapped off.
it's got some nice bits on... remus carbon race cans, full length belly pan...
very low milage too, but the battery is flat, so i can't get an accurate milage til 2mora.
not sure what to do with it.
it's yellow, but a different yellow to my other one.
might build it all across into my still taxed and mot'd frame that i stripped for my project build, would just need to notify dvla of change of engine number before i sell it....
if the milage is as low as i'm told, i could keep the new engine and put my old one back together using its original engine, just the running gear off this'n...
or break it.....
or just swap my spare subframe over and keep it as a second bike....
decisions, decisions.....
best have a
