When you start the bike up, you get a spitting in the air box, apparently there is a K&N air filter fitted, the seller said this is why, knowing better I feel its more the fact that the carbs probably have been rejeted and the fact the owner has put the standered cans back on is making it spit back.
Any thoughts?.
Spitting in the air box.
- benny hedges
Re: Spitting in the air box.
Turn the idle to about 1200 and it more or less goes away
Carb farts are quite normal storm behaviour
Balancing carbs also helps.
I will bring the carb balancer with me on the maintenance day.
does yours have the vac pipe take offs fitted?
I fart a lot if I eat a lot of carbs.........is that what you mean?
If so, stop eating carbs
Not entirely sure, I'll take a look the weekend.bazza696 wrote:I will bring the carb balancer with me on the maintenance day.
It'll have the rear one; it the front one you need to check.
If you look below and to the right of the front carb rubber, where it meets the back of the head, there will either be a rubber pipe of about 10mm diameter coming off, or there will be a cap head screw still in place.
I'll check it out in the morningtony.mon wrote:It'll have the rear one; it the front one you need to check.
i don't normally spit in the air box cause you have to take the lid off , sorry I will get my coat
