47 questions - nearly
Should my STORM use oil between services - if so how much - should it be visible in the oil window - why does my oil light not come on when oil not visible in window - why do i need to top up every 500 miles when no oil leaks and no smoke - am i thick - will it cost - will i have to drink less beer to pay for it? Questions posted in order of seriousness - most important last...
Anyone who bothered to read to the end - your opinions are awaited with thanks....
oil usage?
- essexbloke
Mine uses quite abit also. Bought the bike with fully synthetic oil in there, have been topping up withit too. Do I need to continue topping up with the same grade as is in already or can I use semi synth. Is there any benefit to using fullysynth really?, I was thinking of changing to semi?
Anyone know? advice appreciated..
I got knocked down, but i'll get up again and you'll never ever keep me down!
- tony.wilde1
oil
manual calls for "honda gn4"oil.i think its just mineral oil.dont know whether its any good or not.but its the recommended oil.
When I got my FahrtSturm, the previous owner had filled it with Castrol semi-synthetic. I had to keep topping it up every couple of weeks.
After I changed the oil to Motul 5100 semi-synth, I hardly ever have to top it up.
- Ian in EnZed
(Red 97 FireStorm with Dynojet kit, APE camchain tensioners, bafflectomy+ploogs, UniFilter, GenMar risers, Avon Azaros, 90/130W headlight, digital clock/voltmeter), Braided s/steel lines.
