Long Stacks v Smaller Sprockets
Post by Image »
Which makes the most difference to acceleration?
Re: Long Stacks v Smaller Sprockets
Off the line?
Sprocket.
But you can't use all the power as often, as you have to shut down as the front lifts more easily.
Not a bad problem to have, though.
In third or fourth, grunting out of a corner?
Stacks.
Post by Image »
Hmm, can you have both?
I think stacks prob gets used more then. :thumbup:
Do smaller sprockets cause more stretch on the drive chain?
No more stretch than normal.
When the chain's stretched to the wear limits it needs replacing. How long that lasts is in part down to the smaller front, but tbh it's much more to do with how often it's lubed and cleaned, whether you ride in winter, etc.
Fit a scotoiler and forget it.
The difference in diameter for the chain to roll round is only a mm or two.
Image wrote:Hmm, can you have both?
you can do what you want unless you are insured with bennetts lol!
chain wear - depends on use, proper maintenance, proper lubing, wheelies etc...
have a look at http://www.gearingcommander.com load up the firestorm data and in the custom field, experiment with different sprocket sizes to see the difference it makes...
scroll down, you can see the contacts per revolution.... thas what causes the wear.
it's the number of times the same link hits the same tooth on the sprockets.
ie having a 15:45 set will wear a hell of a lot faster than a 15:41
bad adjustment is the biggest killer though.... slight misalignment will fook the chain.
as will replacing the chain but thinking the sprockets are ok.... they arent lol.
the chain will Immediately wear just the same as the one you just took off!
fit a scottoiler, keep it adjusted and aligned and you should be getting 20-30k from the chain easy.
apart from the fact that a smooth running and well adjusted / lubed chain is smoother and more power efficient, you really do not want it to break on you lol
i snapped one last year,,,, my own fault cos i let it go rusty over winter then just cleaned it and refitted it, even though i had a new set on the shelf....
it damaged my left can, chain adjuster on the s/a, smashed the hugger, smashed the undertray, smashed the gearbox sprocket cover, damaged the clutch slave cylinder and pushrod, but worse, it took out the lugs on the engine where the cover bolts on = no clutch :Ball Kick:
major work required to repair it (properly) as the damage is on the top and bottom crankcases, so basically it's written off a perfectly good engine.
you have been warned lol
Snoogle
Post by Snoogle »
Thanks for that Benny, left mine out in the weather at some points over winter and come to find my chain looking a bit sorry for itself. New parts required!! :thumbup:
should be a priority tbh, if anything it will teach you to look after the chain lol.
i see loads of riders with the chain dangling down way too slack... you can imagine the damage if it comes off lol.... similar to a broken chain but would also wreck the sprocket carrier and swing arm.
feels like a new bike with a new chain & sprocket set so go on, treat yourself :thumbup:
Vtrkidda
Post by Vtrkidda »
Im with bennets :cry: :cry: :cry: they will n
Ever know :twisted: :twisted:
Loud pipes save lives!
Snoogle
Post by Snoogle »
benny hedges wrote:feels like a new bike with a new chain & sprocket set so go on, treat yourself :thumbup:
Yeh I know, I know...lesson learnt :Ball Kick: lol
Post by Image »
Yeah I just been through a winters riding and renewed chain and sprockets. Feels good.
Just got back from dyno .
Standard stacks 103.36 bhp
Billet long hrc copy stacks 105.77bhp
lloydiecbr wrote:Just got back from dyno .
Lloydie, looks like you didnt go for a run to Wales then!
As you beat me to it, you need to answer the questions I wanted answered on the dyno:
what was the Midrange like?
what did the fuel / air look like with the HRC bits.......does it need rejetted?
thats nice and healthy lloydie, i'd be happy with that figure with my bike...... :thumbup:
dyno prints will be posted later :)
NOW
did I mention that I was impatient? :D
