When changing gear at high rpm I have started getting a lot of clutch slip. What is the most likely cause of this?
I am using castrol semi-synthetic oil as before.
Should I just go ahead and chnge the clutch plates or is there something easier I could do?
Bike has only done 45k so I wouldn't have expected the plates to have gone
Clutch slipping
- benny hedges
Re: Clutch slipping
change the oil before you do anyhing m8.
mine always starts to slip a bit when its due.
fresh oil usually sorts it.
you havent used car oil have u with antifriction additives???? its no good for wet clutches.
45k?? mmmh depends how its been ridden. tbh i think if you compare your plates with new there wont be a lot of difference.
if its been slipping a while though, the metal plates could be blued, in which case they will need changing too.
do the oil first.
do the oil first.
Re: Clutch slipping
I changed it 500 miles ago, for the same stuff ( castrol semi synthtic bike stuff) which I always use. Still worth changing it?benny hedges wrote:change the oil before you do anyhing m8.
do the oil first.
- benny hedges
Re: Clutch slipping
SHOULD BE GOOD FOR 4-5K EASY TBH.....
mine was slipping at 5k so i started doing it every 3, with new filter every other oil change.
might be worth you inspecting the plates m8, or just replace them.
dont forget the casing gasket & new coolant.
its also worth before you do anything, just pop the sprocket cover & slave off and make sure its clean, and the pushrod clean too.
bleed the slave / replace fluid, just to make sure its not a problem at that end before you go to the extent of changing the plates.
its an easy job tho tbh, dont even have to drop the oil if you lean the bike right over to the left
Re: Clutch slipping
OK. Thanks a lot for the advice. I did'nt consider tht the coolant would need draining down
I'll probably just go ahead and change the clutch plates at the weekend as jazz of here has got some he can.
Thanks
Thanks
Re: Clutch slipping
Definitely worth removing the front sprocket cover (as Benny says) first. All the chain lube and road dirt/dust gathers in there, also make sure the push rod is clean and moves freely.Steve6088 wrote: I'll probably just go ahead and change the clutch plates at the weekend as jazz of here has got some he can.
Thanks
