Dyno k&n jets
Vtrkidda
Dyno k&n jets
Post by Vtrkidda »
Hello chaps I know throughing money at my storm might not be the best idea so some might say :shifty:
but whats the cost fitted for a dyno jet kit , k&n I can do myself :roll: and dyno runs to improve the carb tinkering
Cheers in advance :thumbup:
I just dont want to fit a kit and it runs like a bag of poopy poop
Is the price worth the gains :confused :?:
So far ive got the throttle mod,long stacks, new filter and plugs,got a 15 tooth front sprocket yet to be fitted was going to bennys today but rain stopped play :cry:
Oh and carbon can comp cans
:think: :think: :think: :think:
Not bothered about top end speed :thumbup:
Loud pipes save lives!
popkat
Re: Dyno k&n jets
Post by popkat »
Fitting the dynojet kits not that bad, bit of a pain getting carbs back on and you have to be carefull drilling the slides, iirc the kit supplies 3 jet sizes, think i used the middle size and the bike ran spot on. Was running DJ kit, K&N filter and Arrow cans, didn't need to spend money on dyno time,
I tried a smaller front sprocket and found it didn't really suit the bike, settled for 1 up on the rear and it was good.
This was all on my old Firestorm.. the new (to me) one may get the same treatment, time will tell :)
Re: Dyno k&n jets
Vtrkidda wrote:Hello chaps I know throughing money at my storm might not be the best idea so some might say :shifty:
fetch it round here m8. few hrs work is all. :thumbup:
Vtrkidda
Re: Dyno k&n jets
Post by Vtrkidda »
Wanted to call over today mate and change the sprocket supervised :lol: but the stupid rain bounced down as you know hows the posh new bike :thumbup:
seb421
Re: Dyno k&n jets
Post by seb421 »
Can I bring mine when its back on the road? providing your free (time)
Vtrkidda
Re: Dyno k&n jets
Post by Vtrkidda »
K&n on the way from a fello member :thumbup: right chaps what jet kits do i need from the bay or any where realy :confused I have no idea what to get :lol:
Loydie your the man for links do yor magic plz :thumbup:
Re: Dyno k&n jets
from dyno jets them selves
http://www.dynojet.co.uk/index.php/vehi ... 1998&Go=Go
i did give a set of dyno jet needles away to someone on here a few months ago
and ive found the springs
you would of only needed main jets £2.50 each :lol:
Vtrkidda
Re: Dyno k&n jets
Post by Vtrkidda »
Oh i see ill have to buy the kit any way :crazy:
So dyno stage 1 is the one for me :crazy:
:thumbup: :thumbup:
Re: Dyno k&n jets
Vtrkidda wrote: :confused I have no idea what to get :lol:
tbh just get on ebay and get some keihin main jets, 180 - 195
then go to b&q & get a pack of m3 brass washers for a quid.
jobs a good un.
dj kit is a waste of money imo. you only need 2 jets out of the kit and the needles are crap.
if you want to pay £80 for 2 main jets then go ed lol!
i have got an ebay receipt somewhere for a seller who's reliable cheap and fast but its buried somewhere lol.
btw dont buy 180 - 195 dynojet mains as they are actually smaller than the ones you have in atm lol!
you need the 6mm thread keihin jets.
Jazzscot
Re: Dyno k&n jets
Post by Jazzscot »
jobs a good un.
Are the 180-195 jets a tried and tested method Benny??
Everything good is bad
Everything bad is good
Re: Dyno k&n jets
i meant a range of jets between those sizes, not just a 180 & 195 jet.
with a k&n plus open cans you will need to go up 5-10 sizes over standard..... cost of the jets about 20-25 quid.
if you look on google you will probably find packs of 10 jets in assorted sizes.
you get better results not bothering with the extra lift hole and just jacking the standard needles.
there is a thread on this somewhere, pasted from superchicken, with dyno results iirc. :thumbup:
also means you wont have to eventually replace the emulsion tubes when the dj needles file them oval!
Vtrkidda
Re: Dyno k&n jets
Post by Vtrkidda »
:crazy: now im lost :lol: what ill do mr benny is ill come over one day and get a list from you :thumbup:
If it ever stops raining :lol:
Plus youll be fitting them :lol: :lol: for a fee of course :thumbup: :clap:
scott02464
Re: Dyno k&n jets
Post by scott02464 »
Sorry to start this thread off again but,
Where would the 'm3 brass washers go for jacking up the needle'?
And how many washers would be a good starting point?
Re: Dyno k&n jets
I already gave you the link to Hawks carb set up guide on the superhawk site. If you read that you would understand where the shims/washers go.
http://www.superhawkforum.com/forums/te ... -up-24769/
You can only richen the needles by adding shims. you can not lean the midrange out at all. The shims go under the e clip which raises the needle which richens the midrange.
If you want to go down the route of using a standard filter then this would work fine. But with the K&N I think you may have a challenge.
templ8
Re: Dyno k&n jets
Post by templ8 »
Just got back from a ride out with a freshly fitted k&n filter. Its running better than ever now, very smooth yet responsive with no flat spots or coughs.
I have scorpion low levels with no baffles and a pair of long stacks in the airbox and a dynojet kit no other mods.
The carbs are set up with 180 mains (dynojet sizes) and dynojet needles on the 4th groove. The slides are drilled for the 3rd hole. The mixture screw is 2 1/4 turns out on the front and 2 1/2 turns out on the rear carb.
Bought the laser carb screwdriver from machine mart and it only just fits but works fine.
