so by fitting a 190 rear tyre would it slow the turn in down a bit?????
all suggestions are welcome.....even the ones suggesting i should lose weight
try a bit more preload in the frontbigspanishmarty wrote:no shock spacer, but the cbr954 forks are shorter than storm shocks, and they're already set the highest point so theres no chance of adjusting them, the only thing i haven't done is re-spring the forks, i might put some thicker oil in for now, and this winter i'll be putting some k-tech or hyperpro springs in.
my tyres at the mo are mis matched, front michelin pilot sport front and perelli diablo rear, both are part worn and both are standard sizes 120/180
seen as i will be in the market for some new rubber in the next month or so, i thought buying a 190 would slow the bikes turn in a bit making it a bit more stable...
To much info.i'll have a quick fiddle, and then i'll look at the pre-load.............![]()
Well spottedcybercarl wrote:To much info.i'll have a quick fiddle, and then i'll look at the pre-load.............![]()
i don't think it does lee, i'll check in the morning, its to dark and scary out there at the mo..........leevtr wrote:Pre load wont make any difference mate. Does your shock have a ride height adjuster?? if so, lower it a bit.
Shouldn't do, mate.bigspanishmarty wrote:t if i go for the 190 the price rise's to £165 and then i might have hugger clearance issues.....![]()
its all good fun tho
