Similar to my Oil question - does a Storm 'use up' clutch fluid. Had to completely refill resevoir twice in 3K miles. No pipeleaks or fluid leaks visible.
Any ideas oh wise ones?
MISSING CLUTCH FLUID
- STEVESTORM
err, slave cylinder seals have gone (and maybe the piston and bore are badly scored too), if you take it off (the three bolts that attached t=o and through the sprocket cover) then you should see it, possible oil, all green etc. That's the only place it can go and it should not use any fluid at all. When you take it off, hold it in place whilst you take the three bolts out then whip if off and hold the psiton in as it will come out as there is a spring behind the piston. You can use a socket and cable tie to hold it all together whilst you take a good look.
Del.
Del.
