Back on the road. Yehaaa
Just had a ride out after putting the bike back together
...........Wow!! Those new fork springs work a treat
Super smooth and goes round corners on rails
- agentpineapple
Re: Back on the road. Yehaaa
have you got your sheep avoidance system in place tho
Well done done Flatty.
yes it does, although I tottered around for the first few miles waiting for the front wheel or something to fall off
All I have changed are the springs to K-Tech to match my weight, they are not progressive ones
Used 7.5 oil
Didn't bother to change the seals or anything
What is surprising is that I haven't even played around with the settings and it feels planted
Used 7.5 oil
Flattie, BigVeeGrin fitted K-Tech weight related springs to his Storm yesterday and needed to cut the standard spacer down, by 10mm on each leg, to be able to get the correct static sag. Good luck.
Sounds good mate. For some reason I thought you fitted Racetech springs, that why I was wondering about the valves. You did grind the rod to a taper as suggested by Sir Roger D though.All I have changed are the springs to K-Tech to match my weight, they are not progressive ones
well done now dont drop it on the grass again lol
Tapered the ends, drilled hole in cartridge but no cutting needed
glad to hear you are back on the road mate ,sounds as though the handlings sorted ,if you fancy testing it,i'm going to squires on wendsday night about 6-30 ,i know some belting roads near sherburn just 10 mins away,if you fancy a run see you there cheerz adyf
well done mate, can't wait for a go once this fasting lark is over
slow is smooth, smooth is fast
- scott02464
Well done with the forks mate glad it's worked out for you!
What do you mean a fasting lark? :-)
It's ramadan at the moment, keeps me busy and off the bike, but only til mid Augustscott02464 wrote:Well done with the forks mate glad it's worked out for you!
it will be raining by then, you might have to cheat on Ramadantasum wrote:, but only til mid August
